‎09-20-2007 08:31 AM
‎09-20-2007 01:19 PM
‎09-21-2007 06:00 AM
I'm using LV and an LED. Well it isn't much of a circuit yet. This is just a start to familiarize myself with LV to automate thermostat testers.
I haven't written a graphiocal code in LV yet, but i was teying to use the writedig.vi and readdig.vi. But I want to use a push button. So it is an external trigger whihc will have to be coded. But I don't really know how to do it.
‎09-21-2007 06:11 AM
‎09-21-2007 06:17 AM
The problem is, I'm trying to configure input on P1.6 and output on P1.5, but I can't configure input and output together. Could you tell me how can I configure input and output. The DAQ Assistant has a note mentioned which states that you can make multiple measurements (like temp, voltage, etc) but they hv to be of the same type (input or output).
Also the data sheet for the NI-USB 6501 shows that there is a input output configuration front panel.vi which can help define each channel individually whihc is shipped with the product itself. But I don't know where that is either.
‎09-21-2007 06:58 AM
‎09-21-2007 07:10 AM
‎09-21-2007 07:41 AM
‎09-21-2007 08:34 AM
‎09-21-2007 08:41 AM
