Nidaqmx does not work in Python IDLE
Hello!
I'm following the instruction on this page https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Pf1SAE&l=pt-BR to read signals with a NI USB 4432.
I installed the NI DAQmx python API with
$ python -m pip install nidaqmx
If I try it again, it returns:Captura_powerShell.JPG
But if I try, on the Python IDLE SHELL, to import nidaqmx with
>>> import nidaqmx
I receive the this error message:
Traceback (most recent call last):
File "<pyshell#2>", line 1, in <module>
import nidaqmx
ModuleNotFoundError: No module named 'nidaqmx'
In Spyder, it works normally, but I need to use it with the Python IDLE.
My Python version is 3.9.2.
Could someone help me? What should I do to NI DAQmx works with Python IDLE?
Thank you!
(5,213 Views)
Accepted by A.Melchiors
Looks like nidaqmx package was installed in your Anaconda environment and not in your IDLE environment.
Please change your PATH variable to point to the Python IDLE folder instead of anaconda.
Santhosh
Soliton Technologies
(5,200 Views)
"Looks like nidaqmx package was installed in your Anaconda environment and not in your IDLE environment."
"Please change your PATH variable to point to the Python IDLE folder instead of anaconda."
Can you tell me how to change the PATH variable as you suggested?
(4,187 Views)
There are several ways to do that, here is a page that explains the common methods - https://datatofish.com/add-python-to-windows-path/
Santhosh
(4,169 Views)
Ok thanks. My Path is already pointing to the IDLE folder though:
For example Path=
C:\Users\harrykuang\AppData\Local\Programs\Python\Python312
My nidaqmx like you said is in:
C:\\ProgramData\\Miniconda3\\lib\\site-packages\\nidaqmx\\__init__.py
(4,161 Views)
