06-30-2008 02:56 PM
06-30-2008 03:05 PM
07-07-2008
03:44 PM
- last edited on
07-17-2025
07:29 PM
by
Content Cleaner
Hi Linkster,
I'm afraid this could be due to a number of reasons. Can you provide me a little more information about what type of Noise you are seeing? Perhaps if you could take a screenshot that would be helpful. There is a knowledgebase here that has some great information you might find useful. Also, the field wiring and noise considerations article, found here, is very useful for reducing noise. It is likely that the noise is due to the fact that we use a multiplexer to switch between channels on the USB 6212. This can sometimes cause something called "ghosting" to occur. If what you are seeing is indeed ghosting, I would take a look at the article here for some ideas on reducing the effect.
I hope this helps,
Paul C.
