Multifunction DAQ
Non-Contact or Tristate Analog Output with PXIe 6363 card
Hello Guys,
I'm working on an application where I need to have 4 analog output (AO) sources permanently connected to 4 loads and in some cases 1 or 2 of them should be used in high impedance mode.
To explain it more clearly, I don't want them to give a potential of -5, 0, +5V etc. but to break the circuit or enter in high impedance (large resistance).
Does the PXIe 6363 card provide this functionality or do I have to connect relays between the loads and the AO?
The connect.vi, disconnect.vi and tristate.vi that I can use in Labview don't seem to support AO connection (attached figure).
Thanks in advance
Nikos
(1,379 Views)
Accepted by NikGR
No, the 6363 AO channels do not tri-state, you need to implement your custom circuit external to the instrument.
Some digital channels support Tri-state and so far never an analog channel on a DAQ.
Santhosh
Soliton Technologies
(1,363 Views)
