Non-Contact or Tristate Analog Output with PXIe 6363 card
Hello Guys,
I'm working on an application where I need to have 4 analog output (AO) sources permanently connected to 4 loads and in some cases 1 or 2 of them should be used in high impedance mode.
To explain it more clearly, I don't want them to give a potential of -5, 0, +5V etc. but to break the circuit or enter in high impedance (large resistance).
Does the PXIe 6363 card provide this functionality or do I have to connect relays between the loads and the AO?
The connect.vi, disconnect.vi and tristate.vi that I can use in Labview don't seem to support AO connection (attached figure).
Thanks in advance
Nikos
(1,366 Views)
Accepted by topic author NikGR
No, the 6363 AO channels do not tri-state, you need to implement your custom circuit external to the instrument.
Some digital channels support Tri-state and so far never an analog channel on a DAQ.
Santhosh
Soliton Technologies
(1,350 Views)
