Not responding to first IRQ level in Windows NT
I am running NI-DAQ version 6.1 windows NT 4.0, and I have a AT-MIO-16L-9 board in my computer.  I can add this device in Niconfig, and add a SCXI-1000 chassis as a SCXI device, which gets verified.  However, when I try to "Test Resources", I can a msg "The device is not responding to the first IRQ level."  On the board, I have the IRQ set at 11.  The only other ports on the computer I can find are COM1 and COM2 which have IRQ set to 4 and Default, respectively.  (Changing these makes it so that the I cannot att a DAQ device.)  Any help would be appreciated.
Nathan
(3,143 Views)
Hello Nathan,
It can sometimes be difficult to diagnose problems with these legacy devices using old drivers on an older operating system. I would recommend that you examine this document which discusses resolving conflicts between PCI and non-PCI devices. I'm not sure if this is the issue you are experiencing, but it may help. Other than that, I wonder has your configuration ever worked? When did you begin to receive this error message? Did anything change when this error message began to occur? A new card in the computer? An upgrade to the driver or OS?
Matt Anderson
Hardware Services Marketing Manager
(3,127 Views)
