Multifunction DAQ
Omega tranducer wiring
I got a pressure transducer from omega with three wires: red (power supply+);black (power supply-); and white for single. It has output voltages from 0 to 5.
The transducer needs a supply voltage between 9 to 30. So I used a  NI 9263 to supply the power (9V) with red and black wires.
I used a Ni 9205 to read the single voltage.
I read the insturction of Ni 9205 and I know there are three different modes: DIFF, NRSE, and RSE.
But in these modes, it seems like I need another wire. Is that true?
I really don't understand. I only have one single wire. How could I do these connections? Can someone give an example in the case of RSE mode?
Thanks!
(4,260 Views)
Accepted by kang2013
Wire the black wire to both 9263 and 9205 (no matter you use DIFF,RSE,NRSE). Be careful that 9263 may not drive enough current for the sensor.
(4,250 Views)
Kateb,
Thanks.  Which channel should wire the black wire in 9205? Common?
(4,234 Views)
Please.....
(4,213 Views)
Wire the black wire to COM, port 17.
Jason H
Automated Test Software R&D
(4,206 Views)
