‎10-31-2006 05:17 AM
‎11-01-2006 01:57 PM
‎11-06-2006 09:50 AM - edited ‎11-06-2006 09:50 AM
Message Edited by Moni on 11-06-2006 09:54 AM
‎11-07-2006
10:18 AM
- last edited on
‎09-30-2025
09:06 AM
by
Content Cleaner
‎11-23-2006 05:01 PM
‎11-24-2006 03:44 AM
I assume that you acquied data with NI DAQ hardware using LabVIEW is that right,
after that you wrote your measurements in TDMS file?
So you want to open this fail in Matlab for future procesing of this data?
If this is true there is solution for you.
The TDM data file format of National Instruments is portable to other applications such as Excel.
After porting the data to .xml or .xls file, you have to use xlsread, xlswrite functions
The syntax is:
DoMnode = xmlread(filename) reads a url or filename
and returns a document object model node responding to the doc.
But basicly I don`t understand why you want to use Matlab for this application,
when NI provide more reliable and the most important - much more faster solution.
‎03-01-2007 04:09 PM
‎03-01-2007 04:30 PM
‎03-01-2007 06:08 PM
Hi Herbert,
Is there something for LabWindows/CVI? -Marvin
‎03-02-2007
09:21 AM
- last edited on
‎09-30-2025
09:07 AM
by
Content Cleaner
