Outputting from pxi-4461 using SignalExpress
I am trying to generate output signals using SignalExpress 2010 and a new PXI-4461 card. To do this I am creating an analog sine wave in the "Create Analog Signal" step and outputting that out of AO0 using the "DAQmx Generate" step. Next, I use "DAQmx Acquire" to view what is actually being output, and the signal being produced is not a sine wave, but some other distorted signal. I have tested out the input channels with a function generator and they all appear to register those signals well, so I am wondering if there is something wrong with the output channels in this card, or if I am using the wrong steps to output the signal. Any input is appreciated.
(3,466 Views)
Accepted by sdltd
I got assistance by phone on this and it is now solved.
(3,459 Views)
how can i initialise PXI 4461
(3,350 Views)
how can i initialise all the channel at the same time in physical channel
(3,346 Views)
Hi arunprasathj,
Since your questions is different from the original question asked in this discussion forum, I would recommend creating a new discussion thread. This will enable your question to be seen by more people.
Best Regards,
Andrew M.
(3,335 Views)
