PC crash after removal of USB DAQ device during analog out generation
I'm using an USB-6251 system on Windows VISTA Ultimate to generate an arbitrary waveform to the analog output terminal.
When I turn of the device during generation my pc crashes and hangs for eternity until I turn the power off and on again.
When my application starts and my device is turned off I get an error describing that the device is not yet turned on. When turning the device off during generation I expect to get an error message from the daqmx driver telling me that the device is no longer available, but it doesn't instead it crashes my machine.
Is this a known problem with the daqmx driver (V 8.6.0f5)?
And can I do someting about it?
André (CLA, CLED)
(3,536 Views)
The crash doesn't occur when running the application on winxp and turning the device off and on.
André (CLA, CLED)
(3,526 Views)
Andre,
I had to lay my hands on a USB-6251 to test this out so that is why my little late respond. I have tested this issue out on Windows Vista Profesional SP1 with NI-DAQmx 8.7.1 and LabVIEW 8.5.1. When shutting the device off during generation I get an error message (-88710) that either the task is aborted or the device is in a state of removal (which is the case here). So this is basically what I would expact.
So I cannot reproduce the crash/hang. Could you try and update your DAQmx driver to the latest version which can be downloaded here:
RikP - National Instruments Applications Engineering
Rik Prins, CLA, CLED
Software Development Engineer
(3,497 Views)
Thanks for the response. But I have had to deliver the device to a customer last monday (who fortunately used win XP). So I cannot perform anymore tests regarding the USB-6251, unless NI provides me with a test device or when another customer comes along that requires the use of this device.
Side question: Is LV 8.5.1 already available for download somewhere?
André (CLA, CLED)
(3,493 Views)
Hi Andre,
LV 8.5.1 is available for download in the Shared Resource Centre.
You have to log in with your  NI Profile.
Bas
(3,470 Views)
