Multifunction DAQ
PCI 4472 external trigger source
Dear All,
I have a PCI-4472B which I want to program in order to acquire a signal from channel 0 whenever it recives a TTL signal throw the External Trigger input.
I'm using a modified example but I don't know which is the name of the external trigger source. I always recive this kind of error (for example if I connect a string containing "EXT_TRIG"):
code: "-200265"
"DAQmx Start Task.vi:1<append>
<B>Property: </B>Start.AnlgEdge.Src
<B>Corresponding Value: </B>EXT_TRIG
<B>Task Name: </B>_unnamedTask<DB>"
The program I'm using is of this form:
First of all, does this error mean that I didn't input the right external trigger source name?
If so, which is the right name of the external trigger source for NI4472B?
Thank you for help
(5,063 Views)
Accepted by tooooommi
Hello there,
The error pops up because there is no channel named EXT-TRIG. If you are receiving a trigger from channel 0, I think the best way is to specify the channel name in the `DAQmx Start Task`.  There is a terminal where you can specify the channel name and use that name as an string input for the trigger. I think this should solve the problem.
I refered from this knowledge base.
http://ae.natinst.com/public.nsf/webPreview/BEBB10D02D72798A8625736B0076B09A?OpenDocument
Also, seems like you have `start analog edge` trigger. Since you want to get TTL signal, why not try `start digital edge` trigger?
(5,050 Views)
It was enough to select  "digital trigger edge", thanks!
(5,000 Views)
