Multifunction DAQ
PCI-6010 and SC2345 connection
Hi
I have a PCI-6010 DAQ card and want to condition to signal with SC modeles. Inheritly using of SC2345 module need.
But how can i connect 6010 to SC2345 carrier.
(3,664 Views)
The SC2345 required an E/M Series 68 pin card or an E Series 100 pin card (see pg 1-2 of the SC 2345 User Guide and Specifications).  The 6010 is unfortunately a 37 pin B Series connector.
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(3,652 Views)
So isn't there any solution to solve this problem for example i can use SCC-68 instead of SC2345 or isn't there any adapter to connect each other.
(3,650 Views)
Accepted by uÖzkan
I'm afraid I wasn't able to find an adapter that goes from 37 pin to 68 pin.  So my recommendation would be that you get a new PCI card (PCI-6221).
Doug
Applications Engineer
Doug Farrell
(3,637 Views)
