02-15-2017 07:44 AM
Hello
My Supervisor asked me to try to run an legacy application running on Windows XP in Windows 7 64 or bit. Frankly i'm not skilled about National Instrument and i'm trying to replicate the sofware was installed on XP. On XP we have a PCI Card Recognized as PC-6014 and i'm looking the correct driver for Windows 7. I tried to install the version i found on Windows XP that was NIDAQ74 and newer version NIDAQ917f2, but from device manager seem that the PCI card is not correctly recognized.
Could someone help me how can i download?
Tanks and sorry for my bad english
02-16-2017
05:10 AM
- last edited on
09-08-2025
04:45 PM
by
Content Cleaner
Hi Giobacc,
if you were using Traditional DAQ on windows XP and you have a Windows 7 32 bit you can use those drivers http://www.ni.com/download/traditional-ni-daq-legacy-7.5/4498/en/ .
I suggest to revamp your application with the newest DAQmx drivers https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288260
LabVIEW compatibility (if you are using LabVIEW) depends on the drivers installed so be aware also of the LabVIEW version!
If you are not using LabVIEW which with sofware are you using that board?
Regards.
02-17-2017 10:29 AM
Tanks for the Help..
As i told i don't know anything about this software....i tried to replicate the software installed on XP
I tried with Windows 7 32 bit...i the driver does not work correct i think i tried also the driver you sent me..but same problem
Last week i have installed all in Windows 7 64 bit and the Driver (16.1 version)seems to be OK as you see in the image
but in this case the error was
wdaq
error loading control. A newer version needed. The default setting we'll be used....
I become crazy
