04-12-2008 03:55 AM
04-12-2008 09:21 AM
Your post is a bit confusing. With 6.1, you can only program with traditional DAQ functions so any programs you wrote before would require you to install the traditional DAQ drivers. The installation of these is not automatic.
If you did install both drivers, then you have to check to see which driver is being used for the card. It might be working in MAX with traditional DAQ. To switch between drivers, see http://forums.ni.com/ni/board/message?board.id=170&thread.id=315357
Using the VISA Find Resource will never find any DAQ boards. They simply aren't VISA resources
