PCI 6025E Product data Sheet has an error
I was trying to trouble shoot a harware problem on a previously working system using a PCI 6025E. I needed the output connections for the digital I/O I am looking at the on-line product data sheet for the PCI 6025E page 12 figure 6 "I/O for the NI 6025E Device". I see that pins 25 through 32 are labeled P1.0 - P1.7 the only problem is that so are pins 97-83. I am guessing that pins 25-32 are really port 0 but can you confirm?
Rick Sharpe
(2,895 Views)
You're right, pins 25-32 are port 0, not port 1.
Joe
(2,882 Views)
Thank you for pointing that out. We will work to correct that error. For future reference, the pinouts in the E Series Help are correct. If you open the .chm file, click on the "index" tab, and type in the key word "pinout." You will see the pinouts for the different E Series boards. I hope this helps.
(2,846 Views)
