PCI 6036
Hi everybody,
I'm new here, so I want to say hello to everybody and thanks for all the efforts you do.
My problem is:
I have Lbview 7 and I work with a DAQ 6036E , it works good but now and still I install the Labview 6i (I must work with it for ma diploma)
Windows XP dont know it any more. Is it a driver problem?? (I think compatibility problem)
In labview 6i there is no CD for drivers.
How can I do?
Please help me.
And thanks.
(4,718 Views)
Version 6i did come with a driver CD but if it's lost, you can download the drivers you need. My guess is that since you were using version 7, you were running DAQmx. That was the first version that supported DAQmx and in older versions you have to use the traditional DAQ driver. You can download the latest version at http://digital.ni.com/softlib.nsf/websearch/3DBF3D343476A28F8625709E006A4937?opendocument&node=132060_US .
(4,703 Views)
I think that the driver from the link you give to me will not work.
Because Labview 6 doesn't support drivers of an earlier version.
I tried with traditional DAQ of the 6 version (last update6.9.3) but it doesn't work.
Thanks for helping and good bye
(4,644 Views)
