PCI 6110
Hello everyone, I have PCI 6110 DAQ card which has a maximum source frequency of 20MHz,I  am generating a  frquency using  MAX.when i generate more than 5MHz.I m getting error which indicates that the desired generated frequency is out of range? can anybody explain what is the reason.
(3,576 Views)
Generating how?  Are you using the Analog Output or the Counter?
(3,567 Views)
hello,I m using counter to generate
(3,544 Views)
