PCI-6115 Counter 0, 1 output current capability?
Can the PCI-6115 drive 50-Ohm loads with either the Counter 0 or Counter 1 outputs? The specification data sheet had no information on this.
(3,279 Views)
Accepted by src42
Hi src42,
The spec sheet lists the maximum amount of current that can be sourced from the digital lines at 13 mA @ 4.35V.  This unfortunately would not be enough to drive a 50 Ohm load.
Best Regards,
John Passiak
(3,269 Views)
