PCI-6115 Onboard buffer not detected
I am tying towrite to the onboard DAC buffer, with the use onboard buffer property enabled, sometimes it works but after a restart of the computer the onboard buffer size is detectead as ZERO and a write to the buffer generates an error.
Iam using NIDAQmx 8.6.1 and Borland C++ Builder 6. I have the VC library converted with the coff2omf utility from Borland, maybe is this the problem.
Is there a NIDAQmx 8.6.1 lib for Borland available ???
(2,926 Views)
Do you mean something like this:
http://digital.ni.com/public.nsf/allkb/B09727F89DA3A06C86256F430071D88E?OpenDocument
DAQmx 8.5 is the last version.
Bas
(2,888 Views)
