12-26-2007 06:45 PM
12-28-2007 11:26 AM
Hi ATMA,
Which file type have you tried (ini, txt, or nce)? What happens when you try a different file type?
Are you trying to export to a network drive or to your local machine? Apparently, MAX 4.2 has issues with exporting to a network drive. The workaround would be to export locally and then copy/move the file to the network location.
If these steps don’t help, your Measurement & Automation Explorer (MAX) may be corrupt. I would suggest repairing it by selecting the Control Panel option to Add or Remove programs, choosing National Instruments Software. When the list populates, select NI Measurement & Automation Explorer, then Repair.
Feel free to repost if you encounter further difficulties.
Saving the System Configuration in Measurement & Automation Explorer (MAX)
01-01-2008 09:33 PM
