PCI 6143 card not seen in MAX
I have a RT target. I ınstall PCI 6143 card on it. I can not seen card on MAX..
(I ınsall drivers by using MAX to RT target.)
What can be the problem
Message Edited by eesen on 01-16-2007 08:17 AM
(3,601 Views)
Hello!
If all SW needed is installed on the target it is most likely due to a corrupt file (during a power cycle for an example) and you can find information on how to fix such issues here (see problem 2):
http://forums.ni.com/ni/board/message?board.id=270&message.id=1520&requireLogin=False
When all SW I refer to the following: LabVIEW Real-Time, NI-VISA Server, NI-VISA and NI DAQmx.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,590 Views)
I thougt that I installed all drivers but ı missed one. When ı install it I can see my PCI 6143 card in the devices and interfaces list. Then installed PCI 6289 card on my RT target. I can see PCI 6143 card in the devices and interfaces list but i can not see PCI 6289.  I trie to reinstall drivers but not work.
Why I can see PCI 6143 but not PCI 6289?
(3,574 Views)
Hello!
Make sure that the DAQmx driver support the board(s) in question and you can find this information in the read-me file that is installed with the driver. Also you say that you have PCI boards and a RT-target so in other words you use a desktop as a target. What kind of specifications do you have on the PCI bus in that computer?
Look at this link:
http://digital.ni.com/public.nsf/websearch/677E9DEF848CD2A386256F160074C97B?OpenDocument
Jimmie Adolph
(3,571 Views)
