Multifunction DAQ
PCI 6259 - Trigger AI voltage measurment when P0.31 changes from low to high
I am writing a pattern using the digital outputs (P0.8-P0.31) and want to trigger a voltage reading on AI16 when P0.31 changes from low to high. Any ideas on how to accomplish this?
(4,329 Views)
Have you looked at an example in the LabVIEW example finder?  You can export a digital signal to a PFI line on the DAQ board.  For an analog input task, you can place a DAQmx Start Trigger VI and choose the source as the PFI line where the digital signal was exported to.
Michael L.
Sales Engineer
(4,296 Views)
Accepted by kphite
Almost what Michael said...
@michael_lewis23 wrote:
Have you looked at an example in the LabVIEW example finder?  You can export a digital signal connect your signal from p0.31 using a wire to a PFI line on the DAQ board.  For an analog input task, you can place a DAQmx Start Trigger VI and choose the use an external sample clock source as the PFI line where the digital signal was exported to.
Best Regards,
John Passiak
(4,252 Views)
Thanks John. That makes more sense. It's not the best solution (all the PFI lines are on the other connector) but I can make it work.
kph
(4,243 Views)
