PCI-6503 card and Delphi 6. I can't use Delphi examples using OCX...
I need to control a led (which simulates a door locking). The original program was in Delphi 3. When I recompile it (without any change), the program simply doesn't work.
I tried to use the Delphi examples given with the installation, but they don't work either. I found how to avoid the EOleSysError exception, but I can't control anything. However, the system is running normally when I control it directly with the test module of the Measurement & Automation Explorer.
If someone has an idea...
Thank you in advance.
Christophe.
(2,706 Views)
In order to use the Delphi examples that ship with NI-DAQ, you need to have ComponentWorks installed. Please refer to README.doc found in ...\\NI-DAQ\Examples\Delphi.
RamziH.
(2,706 Views)
