PCI-6722 How can I put the same waveform with a different phase in different output channels, labwindows/cvi
Hi, i need to output the same signal (the second with phase=180º from first) in two different analog output channels. I don´t know how can i select the channel to output the different signals because  DAQmxWriteAnalogF64 puts the same output for all the channels of the task.
Can anyone help me? Thank you very much.
(2,805 Views)
you can find an example of multichannel analog output with CVI in the following link:
[broken link removed]
AitziberH
(2,799 Views)
