01-13-2007 07:04 PM
01-15-2007 12:54 PM
Hi Dave,
If the device is installed on a machine with no other devices, it will always install as "Dev1". If you need any new devices to install as "Dev1", you can either delete the previously installed device or rename it and then new device will be installed as "Dev1". Other than that there is no setting in MAX to ensure that devices are named in a specific way - by default it names them "DevX" where X increments for each device.
If you want the program to run regardless of the device name and without the user specifying a device, you can use a DAQmx property node to get the active device name and use that on your device.
Hope this helps, please post back if you have any additional questions.
Andrew S
01-16-2007 05:55 AM
The referenced KB solves the problem.
Thank you for your reply.
Dave
