Multifunction DAQ
PCI-DIO-32HS on Windows 7?
Is it possible to use the PCI-DIO-32HS with Windows 7?  If yes, can you direct me to the correct driver to install?
Thank you.
(5,982 Views)
Accepted by aaron.cramer
Hi aaron.cramer
There is a Traditional DAQ driver for Windows 7. The driver does not work for 64-bit operating systems.
This link describes the limitations of the driver and links to the download: http://digital.ni.com/public.nsf/allkb/8EC9E81C3DE4E619862573930083BD7A
Noah | Applications Engineer | National Instruments
(5,957 Views)
Board works under DAQmx, 64 bit Win7
(5,839 Views)
