03-27-2008 03:12 PM
03-28-2008 02:35 PM
03-28-2008 02:40 PM
What LED? Do you mean an external physical LED or an LED indicator on the LabVIEW front panel.
If you are trying to drive an external LED, are you sure that the DAQ board can actually drive it? I don't know the current spec of the board (it will be in your manual), but I doubt it's enough. You usually have to provide an exteranl current amplifier.
03-28-2008 03:21 PM
Hi Dennis,
Thank you for replying to my message. Yes, I meant an external LED. I have tried to make 3 LEDs display the numbers 0 to 7 in binary by using the example "Write Dig Port.vi" that I modified and I have connected the 3 LEDs to the Port1/line0, 1 and 2 of the PCI-DIO-96. And it works without any problems. I have measured the output voltage of the PCI-DIO-96, it is 3.7V so it is enough to drive a LED.
