12-14-2006 12:58 PM
I have 4 machines and two recognize their boards and 2 do not. The two boards that do not work have a PCI-Name property. This seems to interfere with the ability of NI-DAQmx Base to find the board. If you look at the system profiler output and the NI lsdaq utility you get the following information:
| CPU | Ident | lsdaq output | Status | Note |
| Data1Mac | pci1093,162 | 6011E | works | Does NOT have Name Property |
| Data2Mac | pci1093,162 | 6011E | works | Does NOT have Name Property |
| Data3Mac | pci-mio-16xe-50 | --- | BAD | Has Name Property |
| Data4Mac | pci-mio-16xe-50 | --- | BAD | Has Name Property |
Has any one else had this problem? Is there a way to update the firmware on the boards such that they will work with NIDAQmx Base 2.1?
12-15-2006 12:11 PM
12-15-2006 01:33 PM
12-18-2006 05:12 PM
Hi Sth. Thank you for posting this on the community forum. Since we are already working on this issue over the phone, I am taking the thread over from Andrew (NI Applications Engineer). Any findings we have will be posted here, and any community involvement is appreciated. When we come to the solution I will also place the results on this forum.
