PCI6071 - configuration of analog input channels in differential mode
I'm trying to configure the channels of my PCI6071E in differential mode, but I have a problem to configure channels higher than the 7th. Using MAX, I cannot choose to configure the differential mode for all channels higher than 7th. What can be the solution to my problem to set all channel in differential mode? Thanks.
(2,809 Views)
Andrea,
One thing to keep in mind is the fact that the valid differential channels for the PCI-6071E are 0-7, 16-23, 32-39, and 48-55. This is discussed in further detail in the following KnowledgeBase:
Why Can't I Read More Than 8 Differential Channels on My 64-Channel DAQ Board?
You will be unable to access channels 8-15, 24-31, etc.
Spencer S.
(2,809 Views)
