Greetings,
The AT-MIO-16X board was last supported in version 6.1 of the NI-DAQ driver.  Therefore, you must use version 6.1 or earlier with this hardware.  Additionally, version 6.1 is only supported by Windows NT 4 and Windows 95.
The AT-AO-10 is supported by version of NI-DAQ ranging from 4.6.1 all the way up to 6.9.3.  In order to use both boards in the same computer you should use version 6.1 of the driver.
Justin Britten
