Is at-ao-10 board compatable with ni-daq 6.1?
I have a at-mio-16x board installed on my system. I like to know if I could install the at-ao-10 board in another slot. Is ni-daq 6.1 compatable with this board?
(2,646 Views)
Greetings,
The AT-MIO-16X board was last supported in version 6.1 of the NI-DAQ driver. Therefore, you must use version 6.1 or earlier with this hardware. Additionally, version 6.1 is only supported by Windows NT 4 and Windows 95.
The AT-AO-10 is supported by version of NI-DAQ ranging from 4.6.1 all the way up to 6.9.3. In order to use both boards in the same computer you should use version 6.1 of the driver.
Justin Britten
(2,646 Views)
Keyvan,
Yes, NI-DAQ 6.1 is compatible with the AT-AO-10. You should be able to install this board in you system without any problems.
Good luck with your application.
Spencer S.
(2,646 Views)
