Multifunction DAQ
PCIe 62xx Serial Port Driver Issue
Unable to install PCIe 62xx cards on Win10 PC. Tried Dell and HP PCs and got the same results as shown in the attached files. Any help would be appreciated.
(1,019 Views)
What's your NI-DAQmx version?
https://tmesystems.net/
(995 Views)
Are you talking about serial or acquisition interfaces? The question arises because NI PCIe serial interfaces have numbers like NI PCIe-843x, but you indicate PCIe 62xx, which are acquisition boards.
NI serial interfaces require the NI-Serial driver.
(985 Views)
That device has a Vendor ID of 0x8086 which is Intel and a Product ID of 0x1D3D. This is an internal serial port for the Intel Management Service software to access the Intel chipset in your PC. It has nothing to do with any National Instruments software.
This device is supported by the Intel Management Engine Software, which is part of the paid for Intel Active Management Technology platform. Drivers for this device are provided by your PC manufacturer, usually as part of an extra Intel Managed Platform software offering.
Your 62xx card is almost certainly listed in the NI Data Acquisition group, unless it is a very old device that is not supported anymore by your currently installed DAQmx driver.
Rolf Kalbermatter  My Blog
(978 Views)
Thank you for your replay. Uninstall/Install DAQmx solved the issue.
(960 Views)
