PCIe-6323 compatible server
The NI PCIe-6323 is not compatible with a Dell PowerEdge R240 Server. When the PCIe-6323 card is fitted it prevents the server from booting up. Dell's documentation states that the server is Gen3 PCI compliant so it should be backwards compatible with the PCIe-6323 card.
The server's operating system was updated to the latest available but this didn't solve the issue.
Dell have stated that they can't confirm if the PCIe-6323 should work as they haven't tested it themselves.
Numerous different boot configurations have been tried with no success; the server only boots if the PCIe-6323 card is not fitted or if the PCI slot is disabled.
Does anyone know of a recent Dell or HP branded server that is compatible with a NI PCIe-6323 card?
Why Dell or HP? Because those are 2 major brands recommened by NI.
We do know that the PCIe-6323 card is compatible with an older server model,the HP Proliant 360 G4.
(1,579 Views)
i have recently confirmed that the NI PCIe-6323 card is compatible with the HPE ProLiant DL360 Gen10 server.
(1,536 Views)
