PCIe replacement for USB 6211 OEM
Hi y'all,
We want to change our design to use PCIe data acquisition card since we had some USB driver issue in the past. Is the PCIe-6321 a good match to replace the USB-6211-OEM acquisition card?
Are there better alternative?
Fabrice
Best regards!
Fabrice
"If Locals are Duct Tape, then Globals must be toilet paper" Greg Bush
(4,301 Views)
Accepted by FabriceMTL
Hello Fabrice,
Thank you for taking an interest in our PCIe line of DAQ cards. I've taken a look at the USB-6211-OEM and the PCIe-6321 to see if they are similar in specifications and capabilities. I would say that the 6321 is a good match to replace your current USB card. As long as you intend to not use more I/O lines than intended or exceed the designated sampling speed then it should be a good replacement.
If you need high-speed sampling or more I/O lines for various tasks then another card may better suit your needs.
The resource below compares several of our X Series devices (USB and PCIe).
What is NI X Series? - 1. Product Overview
These links may also prove helpful during your upgrade:
Major Differences Between E Series, M Series, and X Series NI DAQ Devices
NI X Series Upgrade Guide (from USB to USB devices however)
Alex C.
Alex C.
ni.com/support
(4,258 Views)
Thanks for your reply Cicco
Best regards!
Fabrice
(4,252 Views)
