Showing results forĀ
Search instead forĀ
Did you mean:Ā
PId temperature control without toolkit
I am trying to create a temperature controller without the PID toolkit.  I am reading in temperature from a thermocouple input in the compact daq 9172 chasis and 9211 module.  And outputing a digital signal into the 9421 as control to some heaters.  Ideally, I would like to control temperature at a setpoint of x+/- 1 degree.  The sensor will be placed directly on the heating element, so time lag would be minimized.  I am not stuck on having to use a PID controller, but it would be nice if I could get something that precise and accurate.  From what I understand, it would be a pretty complex problem using loops, integrals, gains, etc without this toolkit.  I have two questions:
1) is it worth my time to look into building my own PID controller using the standard labview tools (w/o PID toolkit), if so, where should i start?
2) if not, should i just build a proportional gain system where i read in temperature, compare it to a value, then turn on and off heaters depending on whether it's within range?
(4,241 Views)
Or a 3rd option- buy a stand alone unit specific for the job for less than $200. www.omega.com , for example.
"It’s the questions that drive us.ā€
(4,238 Views)
How did the PID controller go?
How did you deal with the Tuninig?
(4,001 Views)
Any body had a luck doing temperature control without PID toolkit?
Also the question is about the tuning.
(3,988 Views)
Here's how one interface device company does it :
http://www.emant.com/686002.page
(3,981 Views)
