Multifunction DAQ
PXI-6120 Digital output frequency
Mcdan,
Thanks, for the you time and effort,
I try to receive it least 200 kHz (I hope to get 500 kHz) out of the digital out,
The problem is that I am not seeing the expected PWM signal on digital lines (the program does not has any error it runs as expected, building the array and all),
the output (measured by scope) is sometimes constant 0 [volt] or 5 [volt] but not PWM (the scope capable measure up to 20 MHz)
and I have a problem when I try to open the VI you sent - error code 9,
Sokal
Sokal,
Message 11 of 13
(1,299 Views)
Accepted by sokal
Sokal,
Apologies, though I saved the VI's for LV 2010, I believe I attached the LV 2012 version.  Let me try again.
Dan
Message 12 of 13
(1,287 Views)
Sorry for the long reply,
i have open your VI,  and you solution work like a charm, 🙂
thanks you for the help and you time.
Sokal,
Message 13 of 13
(1,261 Views)
