PXI-6229 DC Offset
Can anyone explain how to read the spec sheet for Analog Out for a DAQ 6229??  Particularly the DC Offset.  I go thru a number of iterations where I put out a DC voltage from an AO channel on the DAQ.  -8.0 to +8.0 in steps of 1 volt.  One step is zero volts DC.  Zero volts DC +/- what offset????  Currently I get about 13 mvdc.
Thanks..
(2,510 Views)
How do measure?
What timing do you use?
AI and AO have settle times 😉
Don't expect the AI value at the same time you do a AO ...
Greetings from Germany
Henrik
LV since v3.1
(2,488 Views)
