enabling PrecisionWaveformTiming
When querying data from a NationalInstruments.AnalogWaveform<TData>, I can access the Timing member to get timestamps.
The doc tells about the difference between Timing and PrecisionTiming.
However, it is unclear when PrecisionTiming is available.
Can I force "precision" timing ? When creating a task ? When creating the AnalogMultiChannelReader ?
Is "precision" timing automatic according to the DAQ being in use ?
(2,792 Views)
(2,718 Views)
As far as I undestand, it just tells that you can query IsPrecisionTimeStampInitialized, but it does not explain what to do to force that initialization, so that you can use them.
(2,715 Views)
