Multifunction DAQ
PXI-6229 gives error 200019 when acquiring more than 25ch input
I am trying to measure 32ch voltages with PXI-6229 and PXI-8106.
So I build attached VI and It works fine when acquiring less than 26ch input
by setting "Physical Channel" in VI to "PXI1Slot2/ai0:25".
I think PXI-6229 have 32ch Analog Input, but It gives error -200019
when I tried to measure more than 25ch Input by setting "Physical Channel" to "PXI1Slot2/ai0:26".
Please help me fix this.Thanks,
Tabito
(3,131 Views)
Accepted by tabito
Hello tabito
Thanks for posting your question on our discussion forum.
I am Junichi Terao from NI Japan.
I have looked into PXI 6229 specification sheet and your VI , and it seems that the error is caused by the sampling rate that you are using. Please take a look at below PXI 6229 specification (page 1):
http://www.ni.com/pdf/manuals/371290g.pdf
The maximum sampling rate of PXI 6229 for multi channel is 250kS/s (aggregate).  So the maximum sampling rate for each channel can be calculated as follow:
fmax=250k / number of channels
When you set 26 channels and sample at 10000S/s, it exceeds 250kS/s. This could be the reason for the error.
If you are planning to use 32 channels, sampleing rate of each channels has to be below 7842Hz
Sincerely,
Junichi
(3,116 Views)
Hello, Junichi
Thank you for your information.
I understand that the error is caused by the limitation of sampling rate.
I set sampling rate to 6250Hz , my system can use 32 channels successfuly.
Tabito
(3,101 Views)
