PXI-6255 NRSE, RSE configuration
We are using PXI-6255 and are using 60 channels.  Our development environment is CVI.
Questions:
1)  We would like to have one scan list with 59 channels set as RSE and one channel as NRSE.  Is it ok to perform configuration using these steps:
    DAQmxCreateAIVoltageChan // with all 60 channels in channel list, initially setup as RSE
    DAQmxSetChanAttribute (task, ch, DAQmx_AI_TermCfg, DAQmx_Val_NRSE)     // for the one channel that is NRSE
2)  Can accuracy issues occur by combining NRSE and RSE signals in a scan list?
Thank you,
(3,094 Views)
Hi jharris66,
From what I can see, it looks like you should be able to perform the task with 59 RSE channels and 1 NRSE channel. The method you discuss may work. Another option would be to perform two “ DAQmxCreateAIVoltageChan” commands. One command would create the 59 channels with RSE, and other would create the 1 NRSE channel. Have you tried either of these methods yet?
The measurement accuracy should not be affected by the two different measurement configurations. Are you currently seeing problems with this?
Best Regards,
Thomas B.
(3,081 Views)
