PXIe-5662 VS PXI-5650
I'm new in this forum. Please give advice.
Is the programming command set such as frequency set & amplitude set  is the same for the PXIe-5662 as for the PXI-5650?
(4,351 Views)
This forum is for messages about the operation of the forums.
You want to post in Multifunction DAQ forum.  And yes, they should be the same.  Both would use DAQmx.
(4,348 Views)
