Pause Trigger PCI M series ?
Hi folks -
PCI-6225 on a Mac OS X .4 , NI-DAQmx Base 3.1.0. I have a task that uses an external trigger, and want to add new external line to enable/prevent the trigger .
Looks like "AI Pause Trigger" is the signal I want, but how to configure the task ? I only see bits and pieces ...
thanks
Alex
(2,728 Views)
Hello Asquit,
Unfortunately DAQmx Base does not support DAQmx Property nodes so this functionality is not available with your current software setup.  If you have a computer that you can run NI-DAQmx on (Windows OS) then you can look at the following code for information on how to implement a pause trigger using a property node:  DAQmx - AI with Analog Pause Trigger.  Here is another helpful KnowlegeBase article that shows the M Series Capabilities Supported by NI-DAQmx Base.
Cheers,
Brooks
(2,705 Views)
