Periodic delay PXI-6220
Using Ni-DAQmx on WinXP, im acquiring data on demand synchronized on an external pulse(20Hz).
Every data are envenly time space except a periodic 10ms delay.
Is Window could be the origine of that delay?
Any hint?
Guillaume
Message Edited by GPGPR on 02-27-2007 10:38 AM
(2,737 Views)
If you setup a DAQmx task for on demand mode it'll be software timed.  Windows is a non-deterministic operating system, which means that your task will be at the mercy of the operating systems and any other processes that request system resources.  Delays could potentially be the result of using on Demand.
If you board has hardware timing you'll be ablle to setup the acquisition for continuous or finite mode, which will give you much more accurate timing.
Elijah Kerry
NI Director, Software Community
(2,714 Views)
