Possible to build PC based frame buffer using PCI 6111?
I'm considering building a variable scan rate, passive capture frame buffer for Scanning Electron Microscopes. There are no off the shelf frame grabbers that support the clock rates I need and so I'm considering building a line grabber with a DAQ style device and building a frame in PC memory. Has anyone done this. Does the 'setup and run' support of a a PCI-6111 support grabbing video lines in rapid succession and then DMA'ing them out before the next video line comes in? Pixel clock is about 38KHz and 640 samples per line.
(2,987 Views)
Rick Walton,
PCI-6111 does indeed support DMA and handles analog input signals. For image acquisition you would probably be better served by NI�s image acquisition hardware (Analog Image Acquisition)
Here are the specs for the PCI-6111 in case you want to investigate its capabilities further. If you have any other questions please post back! Good luck!
Craig H.
(2,987 Views)
I've already looked at the standard analog video acquisition products and they do not provide enough flexibility for the kind of acquisition I need to do. I need to provide a variable pixel clock to use in sampling video data. It seems only a DAQ board will have the flexibility I want. I need to know if these boards have programmable sampling rates that can range in reasonable increments between 30KHz and 1.25MHz.
(2,987 Views)
Rick Walton,
I noticed that I failed to post the link to the product spec page for the PCI-6111 (it can be found here).
The PCI-6111 can handle sampling rates up to a maximum of 5MS/s (see NI PCI-6111 User Manual).
The sampling rates are indeed programmable at your desired range.
If you have any further questions please post back. You can also look at the NI PCI-6111 page for specific pricing and purchasing inquiries.
Craig H.
(2,987 Views)
