Multifunction DAQ
Problem with AT MIO 64 E-3
I am trying to use an AT MIO 64 E3 DAQ in a Pentium-2 computer, with Windows 2000 as operating system. The same configuration was used successfully by another person few months ago. The problem is when I installed the 7.4.1 (legacy) driver, the two icons for the AT MIO 64 card appears in the device manage, but one of them has the exclamatory sign and it's property shows that "the device can not start (code 10)". The system also shows wrong values of voltage (when I use it with a SCXI 1100 Module, 1303 terminal block and SCXI 1000 chassis).
(3,122 Views)
Accepted by ashiqacrc
Hi ashiqacrc,
It's possible that this has to do with channel assignment on the ISA bus.  Take a look at this knowledge base.  If that does not work, I recommend downloading and installing the 7.4.1 driver from here.
David
Applications Engineer
David
Digital Multimeters
(3,101 Views)
Hello David!
I don't know how I missed that article in the knowledge base because I read almost all the germane ones. The problem is gone, I hope it will be okay now.
Thank you very much!
Ashiq
(3,092 Views)
