Multifunction DAQ
Problem with simulink for daq PCI 6221
hello.. i doing a project to control servo motor using daq PCI 6221. the problem if i can't send the analog output signal usind data acqusition toolbox. Analog output. evrey time i running simulink the problem ' Simulation time must be discreet'
(3,042 Views)
Hi nasadll,
You can test your DAQ card and make sure it is working fine by using the DAQ Diagnostic Utility. If everything is ok with your card I would recommend contacting MathWorks. They make both Simulink and the data acquisition toolbox. Their support page for the data acquisition toolbox can be found here. Let me know if you have any questions.
Nathan
NI Chief Hardware Engineer
(3,023 Views)
