Problems with generation of a FM signal
Hello All
I can't maintain constant the gradient or variation of frequency(df/dt) for a determinate time.
I can see a "noise" in this variable
Somebody can help me?
This is the VI i use now
(2,862 Views)
Hi LNU75,
Are you sure that your noise is caised becase of df/dt ?  Maybe not, because your application your application uses only constant values. Try to review your select  function if is really that what you want.
Filipe Silva
(2,813 Views)
