NI USB-6211
I am using NI USB-6211 to acquire data. How can I measure voltage at high frequency and stop the measurement after a certain time e.g. (5 hours). Do I have to make a program to stop after a certain time? Also what should I use for the acquisition mode  (continuous or N samples) if I am sampling at high rate(1000 Hz)? What about the  samples to read?
(3,452 Views)
Use Acquisition Mode as continuous ( with a while loop) and programatically incorporate a timer condition ( using Timing functions) to stop the acquisition ( the while loop)  after 5 hours.
You should have no problem by setting Samples to read also as 1000, for continuous acq.
By doing so, You will get 1000 samples/sec of data for each of your channels
But one thing of concern: If you are saving the acquired data to a file, It will be a huge data file.
Think of how you would like to handle file saving ( I would suggest you save data in Binary format)
(3,449 Views)
