usb-5102 replacement ac adapter
Hi all,
I have a USB-5102 Digitizer. I have misplaced my AC adapter. What is the part number for a replacement AC adapter (120VAC, US)?
Also, if I wanted to ship this unit to a collegue in France, what is the part number for the replacement AC adapter I would need to purchase for him (240VAC, Europe)?
Matt
(3,535 Views)
This is probably the power supply that you have. It does not mention your device directly, but this is the common USB DAQ Power and it is nor region specific so it can switch to 240V with no problems just get a different Universal Power Cable.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/203861
Cheers,
-Marshall R
-Marshall R
(3,521 Views)
Hello Matt,
There are actually two power adapters (US and European) that you can use with your USB-5102.  The USB DAQ Power supply will not work with the USB-5102.  Please use these part numbers.
US        184351-01 or  184351A-01
POWER SUPPLY,120VAC IN,12VDC UNREGULATED OUT,1.5A,LOCKING PLUG
EUR     184352-01 or  184352A-01
POWER SUPPLY,230VAC EUROPEAN IN,12VDC UNREGULATED OUT,1.5A,LOCKING PLUG
Respectfully,
Rob F
Test Engineer
Condition Measurements
(3,513 Views)
Thank you both for the help and the correction. I dont know if you do this on this forum, but what are the prices for the correct P/Ns (184351-01/184352A-01 (120 VAC ac adapter) and 184352-01/184352A-01 (240 VAC ac adapter))?
Thanks!
Matt
(3,510 Views)
Hello Matt,
The best way to get these devices and find out pricing as well as shipping information is to call us directly.   Just reference the part numbers that are referenced in my previous post.  Thanks for choosing National Instruments!
(800)433-3488
Respectfully,
Rob F
Test Engineer
(3,496 Views)
