Problems with task
Hello, I am programming a signals generator in LabView 7.0 with a DAQ NI USB 6009, everything is ok, but Labview is showing error 200428 due to the task.
This show me a messenge because the task has not been created or has mistakes..To create the task, before, I clic in Tools---NI-DAQmx Base Task Configuration Utility, " create new task " then I place " analogical exit " "analog output". Then I select the channel AO0 and other one in none, save and exit. Then start LabView, open my program and run with the error 200428...
Do I need to form something in the Measurement & Automation before?
Here I attach the .vi in order that they could help me. Thank you!
(3,172 Views)
Since you are using DAQmx functions on the block diagram, you should not be using DAQmx Base configuration. I don't quite understand why you even have that option. Yes, you need to create the task in MAX and under 'Data Neighborhood>NI-DAQmx Tasks'.
You might want to uninstall DAQmx Base in order to avoid further confusion.
(3,167 Views)
